Custom Rear Ballast and Tool Carrier Build
   / Custom Rear Ballast and Tool Carrier Build
Nice build!!!
Love to see Tig welds from someone who knows what they're doing.
Thank you sir. I'm still learning and wish I could TIG more often!
Of note, I did weld the tool carrier tubes to the bottom of the floor so concrete wouldn't seep in;and I was trailing to make everything a sealed unit to prevent any rust in the future. I also then drilled small holes (3/8" maybe) in the floor under each tube (which i could see where they were after welding them) so if i happen to get water down them in the future or caught in the rain, it'll just drain out and dry up.
   / Custom Rear Ballast and Tool Carrier Build #15
Very impressive! One of the nicest one I have seen. Now I want one!
Thank you sir, I appreciate that! I gotta say it's quite convenient. Carry all of my tools for tinkering or fixing things. Carry the saw and can sharpen the chain in the bar clamp. And a decent sized solid work area on top if I need to utilize it. I'll let update the post if I think of anything else I should have added. I can actually drop the chains inside the legs too and transport them if I know ill be using them. That's not often though but I could have added another tube also if it was a major concern. Something for personal consideration.
   / Custom Rear Ballast and Tool Carrier Build #18
Did you try pouring Acetone into the chainsaw holder? Acetone dissolves plastic. You could sacrifice a drill bit and drill a hole into the chainsaw holder at the bottom (would keep water from collecting too) plug it with a natural cork and fill with acetone for a couple of days. Top it off some and stir. then drain out bottom.
then put some plastic in a 'U' sape inside to protect the teeth. The sides could stay concrete...
NEW Landhonor LHR=EPC40 Plasma Cutter (A59000)
NEW Landhonor...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
