Custom-made hydraulic hose needed!
   / Custom-made hydraulic hose needed! #1
Vette1992
Leonard, Michigan
Kubota BX2200
Anyone know a good place to order custom made hydraulic hoses on the internet?
I have a BX2200 with a new BX2763A front blade and a BX2751 quick hitch. The hoses are way too long! The hoses attached to the valve along with the hoses attached to the blade and quick hitch add up to a hose that lays on the ground and gets in the way of the tractor tires. I was hoping to get some custom made hoses to make the installation much cleaner.
Dwayne
   / Custom-made hydraulic hose needed! #2
Do You have the retaining ring mounted on the right side? It bolts to the frame.
I have the same setup .My hoses do have slack but not that much!
I do have the hoses running through the retaining ring, but it doesn't help much. I have two short hoses (6" or less) coming from my hydraulic lever and two long (18" or less) that contribute to the length. I understand if I didn't have the front loader the hoses would hook directly into the valve and not into the hoses coming from it. If I hooked directly to it I wouldn't have this problem.
Thanks.
Dwayne
   / Custom-made hydraulic hose needed! #4
I have mine hooked directly to the valve, but then I don't have a loader .
I have just the stand and valve, which should be close to the same. My quick connects are right on the valve.
   / Custom-made hydraulic hose needed! #5
Vette1992 -
I tore a FEL hose while demolishing an old shed last spring - when I called the dealer - they referred me to a local auto parts store: NAPA auto parts.
$25 and half an hour later i was back in business!
Don't know if you have something similar in your area - but worth a try. Otherwise try:
Surplus Center - 3/8 Hydraulic Hose
They seem to have a nice selection - and very nicely priced - of hydraulic supplies. I just don't know what size the hose / fittings / threads are. When I went into the auto parts store - I had the hose in hand - so I knew everything would work.
Hope that helps,
Dan
Thanks Dan!
I stopped in at a local NAPA auto parts store and for $5 + parts they will make me a custom hydraulic hose.
Dwayne
   / Custom-made hydraulic hose needed! #7
You don't have your profile filled out, so I have no idea as to where in the world you live. /forums/images/graemlins/frown.gif I had some Kubota supplied hoses that were too long and I took them to a Parker hose distributor in Webster MA and they cut them and installed new end fittings. Cost was just for the fitting and installation. If I had a new hose made up, I would have paid the same times 2, plus the cost of the hose. The piece that is cut off can also have a new end put on it at a later date, so keep the stub if you go this route. If you are near Webster MA, PM me and I will give you the information. If not, then call Call 1-800-C-Parker and give them your zip code and that you are looking for a hose distributor. I assume that your Kubota was supplied with Parker hoses like mine.. Faster and less expensive in the end run.. /forums/images/graemlins/grin.gif Junk.........
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
