Custom Light bar for my Kubota L4400
   / Custom Light bar for my Kubota L4400 #1
davygp38
where NY,NJ, and PA all meet
Kubota L4400
I have been searching this site for some time now, getting Ideas for a light bar for my tractor. I decided to make my own, using some steel from a Harbor freight Bed extender. The bed extender was a complete piece of junk, but not a waste of money. I got two 4 foot pieces of 2 inch square stock,out of it, and the pins, and bolts. it's worth more as raw steel, than it is as a bed extender. The L4400 has a work light circuit under each fender, with bayonet style connectors. The wires are black (ground) yellow with red flecks-stripes (hot.) (see the picture) They are fused with a 10 amp fuse in the box. I bought two 55 watt halogen lights from Tractor supply, for $19 each. They seem like good lights, but the brackets aren't the best. Nothing some bigger bolts wont fix. I welded the ends of the square stock closed, and drilled the ends, and welded a mounting bolt, on each. My thinking, is to make the lights adjustable front and back. I also left the bar long. This way I can get a better angle on the hole, if I am digging. Or I can focus out front with out interference from the loader, or a large pallet. I put up some pictures of the light bar after welding. At this point, I wired the lights to a simple three pole switch, to make sure it was going to work. The light circuit on my tractor is on when the key is on. I could have just hard wired the lights,and it would have been OK, but the German in me wouldn't go for it. After testing the switch, I had to find a good place to mount it. I settled for the draft control box on the right. I put it here, because it was close to me while in the seat, and most important, it is more protected from the weather. ( I had thought about mounting it on the fender) Take a look at the pictures, and let me know what you think. I'll post more latter
   / Custom Light bar for my Kubota L4400 #2
I have an L4400 and I am planning on doing putting work lights on the ROPs as well. the lights are the 55W HF halogen mounted in rubber. I will use a piece of unistrut and put the open part down and I will mount 4 lights
(2-front and 2-back). I will use u bolts to clamp to the ROPS, I don't want to drill the ROPS.
I understand your concerns about drilling into the ROPS. I am doing it however, and heres why. My light bar is made of 1/8 inch square stock, and is end welded with 3/16th squares. The bar itself was already drilled with 1/2 inch holes, which is what I am using to attach to the ROPS. As far as I am concerned, The 1/2x5inch bolts. that go thru the rops,combined with the bar makes the rops stronger, not weaker. Since the bar was already drilled, and I would have had to plug those holes, and fabricate clamps, I went with what I had. Here are some pictures of the light bar after paint, and during the wiring process. I am using 14 gage wire, all connections are done with shrink tubing, and liquid tape. I am covering the exposed wires with some vinyl tubing they had at Lowe's for 15 cents a foot. the switch will be greased with dielectric compound, and all parts of the light bar that receive wires, or bolts are sealed with silicone
   / Custom Light bar for my Kubota L4400 #4
Cant wait to see the finished product.
Here is the finished light bar. I was as clean as possible on all the wiring. I used wire wraps, and silicone on all fittings, and connectors. The lights are fully adjustable front, and back. I left enough slack in the wiring to fold the ROPS, and point the lights in any direction. The only weak point, is the switch. I wanted a marine switch , but the only thing locally was the one I used, which is not marine grade. If it stops working, I will order one.
   / Custom Light bar for my Kubota L4400 #6
Looks good, but I would keep it out of the woods.
Mark
   / Custom Light bar for my Kubota L4400 #7
Nice looking job but I have to make mine to where it will be lower than the top of the ROPs and under the
ROPs. I would rip it off in the woods if I didn't. the spread will give good coverage nice job.
Yeah it will be an issue for me, in the woods as well. If it gets to be to big a problem, I will start fron scratch
After carefull consideration, I have decided to fabricate cages to protect the lights from tree branches etc. I just came back from tractor supply with some angel iron, and some 1/2 inch square tubing. I have some 3/16 rod somewhere. I'll post some pics when I gaet started
   / Custom Light bar for my Kubota L4400 #10
Thats a great idea and one you will not regret.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
1268 (A50490)
1268 (A50490)
(2) 500 GAL WATER TANKS (A50854)
(2) 500 GAL WATER...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
