Custom Hydraulic Cylinder company?
   / Custom Hydraulic Cylinder company? #1
bx24
Platinum Member
Indiana
This is killing me (because I cannot find the post) ...
What is the name of the company that gives quotes and builds custom hydraulic cylinders?
This time I will save the link :)
Thanks
   / Custom Hydraulic Cylinder company? #3
arent custom cylinder shops all over the place ? You just gotta find them, but many cut cylinders to length from precision tube and ground, chrome plated rod
All they have to do is lathe a piston, lathe thread to the piston rod, weld caps to it and some standard NPT nipples. many folks can do that.
Renze, I am sure you are right. Todd, Baileynet was the one I was thinking of (thanks).
This was for a friend who needs an estimate to decide whether or not to go to Gehl (OEM) to replace a ram on a BH. I mentioned there were places he could get estimates online to see how the prices matched up (custom vs OEM).
   / Custom Hydraulic Cylinder company? #5
If you know the dimensions you need, try searching Surpluscenter.com, they sell surplus and discontinued cyl's , pumps, motors.:D
   / Custom Hydraulic Cylinder company? #6
For what its worth, I've cut down several cylinders myself to shorten the tube and get a custom length rod. Just put a metal cutting wheel in the table saw and have at it. I use the kind which has the 4 external rods to hold the caps together. Just cut them, too, and re-thread.
Stuff it back together and Bingo, in 1/2 hour you have it on the machine.
   / Custom Hydraulic Cylinder company? #7
If your buddy only needs a new rod, why not buy a replacement rod, have the threads cut on one end and weld on the end he needs on the other side.
This place sells components...
Chrome Plated Metric/Induction Hard
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
RIGID TOOLBOX (A52472)
