Custom High Flow Kit
   / Custom High Flow Kit #1
Schwartz04
Does anyone know where I can get a hold of a high flow kit for a takeuchi Tl150 I am trying to see how expensive they are?
Adam
   / Custom High Flow Kit #2
That is exactly what Supertrak does, is install a high flow pump and add/increase the cooling capacity of the tractor. The kicker is knowing where to get the pump and hardware to install. It might be easier to what till Tak comes out with a high flow themselves and figure out what to do that way. Because I doubt supertrak will willing give you that info. They will happily sell you a tractor with high flow. But, a Rexroth pump is a Rexroth pump!!!
Yeah I knew supertrak sold them but I was wanting to find out if I could basicly do the same thing a little bit cheaper. But I cant find anything about it.
   / Custom High Flow Kit #4
Maybe you could get your eyes on a TL150 that has the high flow pump and just look to see what exact pump brand and model is installed on it? Then turn around and order yourself the pump.
Then you still need to worry about the cooling issue, but you can always order yourself a larger capacity cooler too.
   / Custom High Flow Kit #5
Since Gehl has a high flow and they are Takeuchi's why not look into getting Gehl parts?
Takeuchi (us) has not released a high flow because they feel it runs the motor too hot.
   / Custom High Flow Kit #6
Gehl and Mustang mount an additional pump out on the engine and combine flows with the standard aux pump to get their flow.
2025 CFG Industrial QK18R (A50123)
2025 CFG...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
1992 Ford E-350 Ambulance (A51692)
1992 Ford E-350...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
