Custom console for 3X20 Tractors and Upgrades
   / Custom console for 3X20 Tractors and Upgrades #11
matthew3120 said:
Here is the Item numbers for the switches I got from John Deere dealer. This a custom switch from the 3x20 and 4x20 line up of cab tractors.
Work light Switch
-MIA10204
-2006011DY2
Matthew3120
Ok, just got off the phone with the dealer and had partial success.
Part Number: MIA10204 - Switch $16.23
Part Number: 2006011DY2 - dealer can't figure this one out....what is it..?
Any more insight is appreciated.
Thanks,
Derek
Thanks,
Derek
Never mind this Item number 2006011DY2 It was on the side of the box the switch came in.sorry about that.
matthew3120
   / Custom console for 3X20 Tractors and Upgrades #13
matthew3120
Thanks for the update, guess I will call the dealer back and order a few of those switches.....gotta save up some projects for rainy weather season (right around the corner).
Thanks,
Derek
Thanks,
Derek
hope the switches work as good for you as they are for me.they are weather proof.Now I am waiting for my 2 sets of forwarding lights to come.Good luck
matthew3120
   / Custom console for 3X20 Tractors and Upgrades #15
Ordered out three switches today - Thankyou for these part numbers. Price was $14.32 each. Also ordered out the JD Brush Guard kit for the lights - $32.00 - so I can mount my own set of lights on it. That or just order the JD ones at a future date - I am having a problem convincing myself they are worth that much money just because they come from Deere. Any apreciable difference between the JD ones and the nice metal lights from Tractor supply? Are the JD light beams flood or spotlight?
My forwarding lights and rear work lights are flood lights.The forwarding lights are going to make big emprovement when plow snow with the loader
matthew3120
   / Custom console for 3X20 Tractors and Upgrades #17
Not only do you get the lights, you also get the wiring harnesses to make the install easier, even though it is still a pain in the rear to fish the wires down the rops or up the rops, depending on which direction you want to go. I installed both forward and rear worklights when I did it and am sure glad I did.
Derek
   / Custom console for 3X20 Tractors and Upgrades #19
O'k, looks great, but drive this in my head. How did you connect from the original fuse box to the new one? I see the wire going into the box, but no plug or connector to connect the two. Is there a part # or connector to put in the JD box? Also I want this circuit to cut off when I shut off the switch. I'm going to use this as an aux. switch for a sprayer.From what I see the only way is to add a relay and it's easiest to piggyback to the original box. These boxes give this slipon option, but I can't find a part# or any support from JD.
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
3650 (A47477)
3650 (A47477)
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2019 ISUSZU NPR BOX TRUCK (A56129)
2019 ISUSZU NPR...
