custom built hydraulic cylinder?
   / custom built hydraulic cylinder? #1
nasdaqsam
Upstate NY
Kubota BX23
Any ideas or links to finding a company that builds cylinders to your own needs?
Not looking for anything crazy just looking to have a cylinder built with the inlet/outlet ports where I need them instead of the stock location.
Thanks in advance
   / custom built hydraulic cylinder? #2
Try Bailey at Baileynet.com . They build custom cylinders and also manufacture their own Chief brand.
Thanks Madman, Why did I know it would be you coming to the resuse? Although I am bit disappointed it took you 11 minutes. LOL
   / custom built hydraulic cylinder? #4
If you need both fittings on one end, there are many off the shelf loader cyls with that design. They supply through cylinder rod. Might could save you a bundle off a custom build if found with right bore, stroke etc..
</font><font color="blue" class="small">( If you need both fittings on one end, there are many off the shelf loader cyls with that design. They supply through cylinder rod. Might could save you a bundle off a custom build if found with right bore, stroke etc.. )</font>I wouldn't mind the price so much as the wait time. I kinda need the thumb now so I am going to have a shield built for now and try to find or order a custom cylinder.
What I need is not so much on one end (however that may work also) but to have the ports on the side instead of on the bottom as shown in this picture. There just to prone to a problem.
   / custom built hydraulic cylinder? #6
What kind of end does the cylinder have. Why not have it cut off and rotated 90 degrees? Should be able to find a shop that will do that kind of work in a day.
</font><font color="blue" class="small">( What kind of end does the cylinder have. Why not have it cut off and rotated 90 degrees? Should be able to find a shop that will do that kind of work in a day. )</font>I never thought of that. Good idea. This is a link to the cylinder I am trying to modify. Can this one be cut and rotated?
link
This is my first time hooking up a link so I hope it works.
   / custom built hydraulic cylinder? #8
Without getting a close look at the cylinder ends, I would guess the fixed end could be cut off and rewelded. Any good hydraulic shop or even a welding shop could do it.
   / custom built hydraulic cylinder? #9
Yep that does look problematic. Is that a JIC to pipe adapter on cyl? Looks like you might could go with pipe to tube L and turn cyl 180deg. I can't tell if mount would allow that from pic though. It would offer great protection if it would work.
On my big hoe the tubing is maybe inch and a quarter high on cyl and that's 5/8 tube. The port, and or adapter on your cyl seems exceedingly long (almost width of cyl) before it turns 90deg . I note the boom and dipper look more normal. Good luck with it.
   / custom built hydraulic cylinder? #10
I would remove the piston. Cut off the cross tube and weld it at 90 degrees. Did a similar modification to one of my 3PH tilt cylinders today. About an hours work. A little longer for paint to dry.
You may not want to rotate a full 90 degrees. It looks like the top port would be very close to the mounting bracket.
2010 Nissan Sentra Passenger Car (A51694)
2010 Nissan Sentra...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
