Cushman trackster
   / Cushman trackster #1
ernemats
Veteran Member
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Does anyone have a Cushman trackster and if so do you have any problems that you should look for when buying one. They look like a fun machine to have. I know they were only made in the early seventies and they are hard to find.
   / Cushman trackster #2
hello i've got a couple tracksters both with cabs, they are a neat machine mine still have the omc opposed twin cyl 2 stroke, they are extremely loud, they did have problems with the motorola ignition module other than that there pretty dependable. there was a company out around salina ks that bought the tooling and was making a newer version. most people swap the original engine for a honda or similar hope this helps.
   / Cushman trackster #3
I had one too, biggest problem I had is, the aluminum bogie wheels coming apart...
To be honest, I was glad to see it go...
SR
   / Cushman trackster #4
those little omc engines if tuned right are near bullett proof,
which do you have???? 18hp has sparkplugs on the bottom and 22 hp has spark plugs on top
if it has electric ignition its not stock ... should have points (what do you think of that two coil mess?)
anywho the number one cause of a wimp omc after sitting is a dry dist/gov.
the timing advance weights stick ... few drops of sae30 down the rotor shaft and 10 mins idleing is an easy fix and should be done anytime the engine sits more than 3 months
Wolverine Mini Skid Steer Combination Bucket (A50515)
Wolverine Mini...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
Kubota GR2120 (A47384)
Case CX210D Excavator (A50514)
Case CX210D...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
