<font color="green"> I guess the engineer in me says that it seems to have nothing to do with the curved loader arms and everything to do with the slopped hood. If you redesigned the engine compartment of the Kabota and put a slopped hood on it, you would have equal views.
</font>
Rozett, take a closer look. You can actually see top of the bucket over the top of the loader arms on the NH. So other than where the hood is, the bucket itself is what is blocking your view, not the arms.
Also, consider the
B2910/LA402 combo actually has fairly low profile loader arms (the loader arms are at the same level as the hood when the bucket is as rest). What that means is that the Kubota is actually a tractor with a fairly good view. Dig around a bit and find a tractor with a Kyoker loader and see how high the arms sit. Or take a look at some of the Mahindras. Or take a look at some of the Jinmas. Many of those units have arms that are actually above the hood when the bucket is as rest. There is a little Jinma unit that has been for sale for months near me, the loader arms are probably 6" above the hood. The higher the arms are the worse the view is because it compounds the problem of visibility.
NOW, consider that when you actually work the tractor you do not typically have the bucket all the way down for most of the work. That means that no matter how bad the view is when the bucket is at rest, it is worse when you are moving because the arms come up and block even more of a view.
Ugly or not? That is a matter of choice.
Functional or not? I think the debate of that should be about ending with these pictures.
Strong or not? The loader ratings on the tractors place their capacities at the upper range of the spectrum.
Personally, after using the
B2910 to clear a 1 acre industrial field early this summer and then coming home to the TC24 in the evenings I can tell you that I am convinced that there is no real comparision when you actually work with these things. The curved arms make work go faster.
