curtis cab wiper motor
/ curtis cab wiper motor #1
clemnd86
Wareham, MA
Kubota BX 2200
I have a BX 2200 with a curtis cab. The wiper motor appears to be kaput ( it may be the attached switch). I seem to recall reading on here in the past ( I searched but didn't find anything) that the wiper motor is fairly common and I don't need to go through the local curtis cab dealer and overpay with snow on the way. Any ideas?
Mike
/ curtis cab wiper motor #2
You might get lucky and you might not. We stick with factory original for the most part if available but have found that there are a lot of different wiper motors out there to order and not be right.
/ curtis cab wiper motor #3
Not trying to insult you - are you sure its the motor? I thought my motor was bad because the wiper stuttered across the window or didn't move at all. I recently noticed the motor shaft was agitating back and forth as it should but the arm is loose on the shaft. I have to figure out how the wiper arm attaches to the motor shaft and see if it can be tightened.
