Gregster613
Platinum Member
- Joined
- Apr 19, 2009
- Messages
- 832
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi fellow 273/293/233 owners, I've been struggling to discover why my loader control valve (on the curl/dump side) seems to be extremely stiff lately and thought I'd ask if any others have had these symptoms?
After it runs for about 1/2 - 3/4 of an hour they seem to loosen up some. It seems as if once the hydraulic fluid warms up some it clears itself up? We don't even have "cold" weather here!! I had similar problems a few years ago with the lift/lower/float side and learned that it was fixed by taking off the end cap, cleaning and re-greasing.
Well I have done that same thing on the curl/dump side twice now and it only makes the control lever free and easily movable for about 1 -2 days then it's the same issue again. Also of note, once the cap is off then all works as smooth as new? I can move the control lever side to side freely and smoothly? Put it back together and smooth as silk for couple of days and then wham back to almost impossible to move side to side! The lift/lower/float works smoothly all of the time. I'm getting vexed by this and wondered if any others had had similar issues like this?
When I say stiff - it's practically moving the entire fender section it's attached to in order for me to get it to move at all! I'm getting afraid that I might break something if I don't manage to figure out what is causing the binding. It's not the three balls under the flap that attaches the cables, nor the cables themselves. It's pretty uncanny that once I remove the end cap all seems to be free and flexible. Clean it all, apply some grease, reassemble and a couple of days later need to do it again?? I'm hoping some one out there has had this and gotten it fixed but just not seen any need to write about it and can shoot me an answer that fixes me again.
I could (maybe should) have put this in the hydraulic section but right now I'm looking for any TYM owners who might have an answer for me.
Thanks, Greg
Thanks, Greg
