Curious how easy this to do...
   / Curious how easy this to do... #1
corvarea
So hey guys I'm new here so try and take it easy on me :). With that said I just bought a used 2005 Cub Z Force with a 44" deck on it. I love the way it cuts and it saves me tons of time. The only thing I didn't notice when I check it out before buying is the tracking on the mower. What I mean here is the left handle has some play in it compared to the right. In the neutral position both handles seem right. When I push them both forward I think everything is close I might veer a little to the left.. Its when in the neutral position and I go to pull back I can pull the left handle maybe 4" before it starts to do anything. Is this just a simple adjustment? If you want I can load a video to show what I am talking about... (Sorry again I am new to zero turns.. :(. ) Thanks guys for any help
   / Curious how easy this to do... #3
Before adjusting, check all linkage points for looseness. Replace any loose joints before adjustment.
I bought a 44" Z Force in 2005 or so. It had Briggs and Stratton engine that turned out to be disastrous. I hope you don't have a Briggs on yours. It did indeed drive and cut extremely well.
Good luck,
Hey thanks. Im hoping this is just a easy fix and not a major issue with my mower.
Mine has the 20 hp kohler engine.
   / Curious how easy this to do... #6
A Kohler? GREAT! I bet it serves you well.
   / Curious how easy this to do... #7
I had the same problem a few weeks back on my RZT50. I thought the right side steering damper had broken off, but it backed out of the threaded end. I just threaded it back in, had to remove the battery for access.
Steve
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
2014 Volkswagen Passat (A56859)
2014 Volkswagen...
1996 JCB 506B Telehandler (A57024)
1996 JCB 506B...
2019 John Deere 85G Midi Excavator (A55851)
2019 John Deere...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
