Cummins small cam oil filter Napa gold 1970 and what oil
   / Cummins small cam oil filter Napa gold 1970 and what oil #1
bigrich954rr
oregon
branson 4720h 6ft brush hog ,post hole digger, ripper, pallet forks,
I got a old Cummins small cam it leaks some oil but going to change the filter and oil.
Unsure what filter to use the one on it is a Napa gold 1970. What to know what other filter I can use that would be better ?
Also what oil to use as I know the small cam Cummins had cam issues and not sure if the new oils will make that worst or better ?
   / Cummins small cam oil filter Napa gold 1970 and what oil #2
You talking an old 855???
We run a lot of them back in the day, never a cam issue.
We ran DA 30 or Rotella t 15-40
   / Cummins small cam oil filter Napa gold 1970 and what oil #3
Fleetguard and Wix filters were the filters I always used on my 855 and 903.
Used Chevron Delo 30w till 1980, then switched to Shell Rotella 5w40.
I don’t remember small cam 855’s having cam problems. I believe the big cams did when they first came out.
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
HarbinGer V3 Plus Towable Light Tower (A52377)
HarbinGer V3 Plus...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
