Cummins small cam oil filter Napa gold 1970 and what oil
   / Cummins small cam oil filter Napa gold 1970 and what oil #1
bigrich954rr
Bronze Member
oregon
branson 4720h 6ft brush hog ,post hole digger, ripper, pallet forks,
I got a old Cummins small cam it leaks some oil but going to change the filter and oil.
Unsure what filter to use the one on it is a Napa gold 1970. What to know what other filter I can use that would be better ?
Also what oil to use as I know the small cam Cummins had cam issues and not sure if the new oils will make that worst or better ?
   / Cummins small cam oil filter Napa gold 1970 and what oil #2
You talking an old 855???
We run a lot of them back in the day, never a cam issue.
We ran DA 30 or Rotella t 15-40
   / Cummins small cam oil filter Napa gold 1970 and what oil #3
Fleetguard and Wix filters were the filters I always used on my 855 and 903.
Used Chevron Delo 30w till 1980, then switched to Shell Rotella 5w40.
I don’t remember small cam 855’s having cam problems. I believe the big cams did when they first came out.
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
Massey Ferguson 9250 (A55301)
Massey Ferguson...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
