Cummins and Kukje
/ Cummins and Kukje #1
Yalerider
Woodland, Washington
Branson 3510i w/FEL
I've been researching the deal between Kukje and Cummins. I find it interesting that the Cummins A-Series engines which are used in Branson tractors are listed on the Cummins site as two horsepower more than the Branson's specs. Wonder why?
Cummins A Series Specs
Model Cyl Bore x Stroke Displ. Hp * Torque ** Weight
A900 3 72 x 72 mm 0.88 L 18 38 lb.ft. 254 lb.
A1400 3 84 x 88 mm 1.46 L 31 69 lb.ft. 386 lb.
A1700 3 88 x 84 mm 1.71 L 37 82 lb.ft. 386 lb.
A2000 4 84 x 94 mm 2.08 L 45 102 lb.ft. 430 lb.
A2300 4 88 x 94 mm 2.29 L 50 111 lb.ft. 430 lb.
A2300(T) 4 88 x 94 mm 2.29 L 60 135 lb.ft. 411 lb.
* - at 2800 rpm
** - at 1600 rpm
/ Cummins and Kukje #2
They are rated at 2600rpm in the tractors and at 2800rpm in other applications. The extra 200 rpm gains the extra HP. They could rate at 2800 rpm, but that would be faster than is proper for the PTO so it wouldn't be a good number.
/ Cummins and Kukje #3
Check the RPM you will find the comparable engine in the Kukje tractor runs at a lower RPM.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ Cummins and Kukje #4
Guess that is what happens when you do not scroll down the page to see the other posts.
Happy Tractoring
