Cummins 5.9 water pump repalcement
   / Cummins 5.9 water pump repalcement
Boy, this water pump thread sure went off on a tangent!
Update: Friend called today, was in town at a funeral home for a visitation and just before he got there the engine temperature went to the top of the range. Went back out a while later and said there was no water visible in the radiator, but the reservoir was still full.
I went in to take a look at it. Was just as he said, nothing in the radiator and the reservoir was right where I had filled it, and no visible leaks. He came out and said someone had seen him pull in the parking lot and said it looked like the left tire was smoking. He had checked it and it was no hotter than the right side, only warm.
I pulled the dipstick, and low and behold it was two gallons over full with gray goo. That's not good, looks like a blown head gasket. The head was replaced last summer with a new one, but I suppose it could be cracked. The original head had cracked in one of the exhaust ports, and it only had 130K on it.
So I called a friend that does any of my automotive repair that I don't want to do, and he said he could get it in the first of next week. That was good, so he sent a tow truck and picked it up.
Took my friend back to my place and gave him my '04 Town Car to drive. He and his wife live in Gaylord, MI, 270 miles north of me. They have borrowed the TC four or five times before when they have had car or truck trouble and needed to get back north. I think they have put more miles on it than I have. Luckily, I just recharged the A/C last week, so it blowing nice and cold again. Was the first time in the 14 years I have owned it that I have had to recharge it.
I'll report back when I get the diagnosis. I hope it's nothing more serious than a head gasket. I wonder if they need to be retorqued after so long?
On the other end of the spectrum, I have another friend with a '95 Dodge 2500 duallie he pulls boats with. Has over 1,100,000 on his 5.9 and has never had the head or pan off it. I've been harassing him about at least putting a set of bearings in it.
   / Cummins 5.9 water pump repalcement #22
Actually, it’s not weird or random and it is backed up by facts
And IMO, 5030 is right. Auto manufacturers are run by bean counters who sit around and fight with each other about saving 5 cents on a part from China.
Now their chickens are coming home to roost.
You don't find it odd to talk about ford microchips issues in a Cummins water pump thread.
OK.
   / Cummins 5.9 water pump repalcement #23
The h20 pump in my 06 2500 with the 5.9 failed me once in rural Montana. I swapped it out in a Napa parking lot and was back on the road in less than an hour.
   / Cummins 5.9 water pump repalcement #24
Isn't it recommended to re-torque head bolts after one changes a head gasket? Would hope that this is the issue and not a cracked head (or warped).
Is this engine stock?
Having two head gasket problems is kind of like lightning striking twice in the same place. Can happen, but the odds are pretty remote. Now, then, if big mods then that is an odds leveler... (but it takes a bit)
Regarding the (off-topic) chip shortages, Toyota learned about this supply weakness (in their Just In Time process) following the Fukushima nuclear meltdown event. They decided that critical, hard to source, items should be stocked in larger quantities: they were being too literal with their JIT; the overall process was about getting out a good product, not necessarily keeping parts bins small...
I don't know, I've never worked on a 5.9 before, but I guess it would depend on the type of head gasket that was used. If it was an all metal steel shim type, like the old NTC engines used, then no retorque is required. If it's a sandwich type, then probably so.
The engine is bone stock.
This is the first head gasket problem on the engine, the previous problem was a cracked head.
In further conversation with my friend, about 3,000 miles after the head was replaced, while on a trip, the oil light came on and the oil pressure gauge fluttered up and down.
He stopped immediately and checked the oil, there was none on the dipstick. Fortunately there was an auto parts store across the street, so he bought some oil and ended up putting in five quarts. The engine holds nine quarts. It had never used oil before that, and hasn't since. So, the repair shop apparently only put five quarts in and never checked it. That doesn't give me a lot of confidence in the rest of the work they did.
   / Cummins 5.9 water pump repalcement #26
OK.
Just responding to your unpredictable turn off topic bro.
   / Cummins 5.9 water pump repalcement #27
Heck no. I can see why not. Wonder how far he ran on 5 quarts. That’s Cummins abuse!
   / Cummins 5.9 water pump repalcement #28
My 2004.5 Cummins takes 3 gallons for an oil change. I looked in a few places and it seems they take 12 quarts in 1993 and 1994.
My aftermarket water pump failed with less than 30,000 miles. Probably a Gates water pump. Cheesy Murray pump installed with a lifetime warranty. If it crums out prematurely I may go and get a Cummins sourced water pump.
   / Cummins 5.9 water pump repalcement #29
Yeah, all the 5.9 and 6.7 Cummins used by Dodge / Ram are 3 gallons oil capacity
   / Cummins 5.9 water pump repalcement #30
Cheesy Murray water pump lasted 5 months and less than 4,000 miles. Leaking from weep hole. Warranted and changed but still. I guess I need to get a Cummins water pump to carry with me.
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A48836)
2008 Hino 268...
1993 Harsh Feed Mixer (A50397)
1993 Harsh Feed...
2016 Quincy QSI-370i Rotary Screw Air Compressor (A46683)
2016 Quincy...
2013 John Deere 350G LC Hydraulic Excavator (A46683)
2013 John Deere...
CASE 1850K LGP SERIES 3 CRALWER DOZER (A50458)
CASE 1850K LGP...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
