Cubb Cadet ZForce or Toro Z553
   / Cubb Cadet ZForce or Toro Z553 #1
Confuuscious
Delaware/Maryland
John Deere Gt 325
/forums/images/graemlins/confused.gifI am stumped. Im not sure if I want to get the CC ZForce 50 or the 60 Inch Z553 Turbo Force Model 74244, they both have V-twin Kohler Engines. I see where Toro has some additional things over CC. I have almost 5 acres and I cut almost another 9 Acres. the majority of it is flat, bumpy in a few spots. I live on the Eastern Shore of Maryland. I know the CC is $3,999 I have been offered the Toro for less that $7,000. I have been eyeing the CC M60 Tank, however that is $8,000. I can't justify paying that much. Now that I have offered Toro, Im afraid to pass this up, however I know nothing about Toro Mowers. I have a Gt 325 JD now but I want a ZTR. anyone have any info............
   / Cubb Cadet ZForce or Toro Z553 #2
The two mowers you have mentioned are very different.
IMO the CC-Zforce50 would barely be adequate for your almost 5 acres ,and when the thrill wears off it will be a chore especially if the machine starts giving you trouble. You can forget about cutting the other 9 acres...
Now if it is between the CC & the Toro , Go with the Toro , It is much more machine and should handle your 5 plus the 9 you mentioned. It appears to almost be an entry level commercial wanna-be
Now I have a question for you.. If you are thinking of spending almost $7K ... Do you have any of these dealers near you ?
A. Hustler , Fast track less than $5K or hustler Z $?
B. Lesco Z two 60" $6300 25hp kawasaki(same as M60 tank) also 60" 28hp generac $5399 both commercial units
C. Gravely 152Z or 160Z good equipment as good as the toro or better for the same price ...
There are a bunch more machines out there that are used much more commercially but these are the ones that I can think of that are around $7K or less... Good Luck Now go spend some money!!! /forums/images/graemlins/smirk.gif
Once again this is IMO /forums/images/graemlins/smile.gif
   / Cubb Cadet ZForce or Toro Z553 #3
I agree with Nasty135. You need a commercial machine. Along with the units he mentioned, I would also look at ExMark, GrassHopper, and Dixie Choppers.
   / Cubb Cadet ZForce or Toro Z553 #4
I agree, if you are spending that kind of money ($7,000), you should look at a few more machines. I would suggest one of the Hustler models, based on build, warranty. And for the amount of mowing that you will be doing, you will want more mower, not less.
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
