Cub Yanmar
/ Cub Yanmar #1
jeepfreak1972
MI
Kubota L3800 HST
Are these reliable sturdy tractors? I think they look nice and if Yanmar is involved they should be great. I'm kind of interested in the EX3200. I currently have a Kubota B3200.
Steve
/ Cub Yanmar #2
Well I have had the SC2400 for almost two years have about 650hrs on it. The tractor has been strong starts good runs economicaly I had a bit of problems with the snow blower or should I say lots but they stood behind it replaced it and its working really well
/ Cub Yanmar #3
I've had EX2900 for alittle over a year currently have 120 hrs. on it and its done everything I've wanted. I use it to bushog, work up food plots and landscaping. The only thing I'd do different is try to work power beyond remotes in with the deal, the other day the dealer quoted me a price of $1200to install.
/ Cub Yanmar #4
So far i have been extremely pleased with my EX450.:)
amaxwell
/ Cub Yanmar #5
I've got the last generation Cub, but everything I've seen and heard is Cub got this series right on the money.
Good luck!
/ Cub Yanmar #7
I've had an EX3200 (tractor and loader) for over a year now. Good tractor. Use it to work food plots, cut brush, and garden. Have used it without a problem with a 5' Bush Hog, 5' tiller, and 5' disk. Have about 100 hours on it. Only issue with the tractor is not its fault. I'm a big guy and the operating platform is kinda tight. Would recommend filling the tires. It feels a little tipsy on the hillsides around here.
/ Cub Yanmar #9
Question why would you want to go from a B3200 to a EX3200? Basically the same size tractor with the the edge to the Kubota. Kubota had stronger loader, higher 3 point lift and larger fuel tank.
DevilDog
/ Cub Yanmar #10
Curious if some you that have the EX450's would mind what you paid for? I got quoted $25k last spring for a new 2010 model. My dealer just called me up last week and said he came down to $23,600 w/fel. Last chance before new models come out w/ a 3% increase. I still think it seemed a lil steep for what others were paying when i checked into this last spring. I'm really itchin to get my first tractor just cant pull the trigger. Just had to put 10k into a rebuild on my 7.3L f350 motor. Thanks all
/ Cub Yanmar #11
Where are you located? Have you shopped around with different dealers?
I bet you could get it for less than the 23,600.....
10K in a motor rebuild??? Ouch...
/ Cub Yanmar #12
Not sure where you stand on this tractor but I own the little brother, the SC2450, yes not a big tractor but a good one.
The quality of the tractor is what I wanted to state, good quality, well laid out, good fit on most of the parts, in the eight months I have owned my tractor it has worked great.
The design of the tractor is good, they took ideas from real people and added them in.
This little guy works hard for me, works without questioning me and if the larger ones are built as well then you can’t go wrong.
Luck
/ Cub Yanmar #13
Wow, that's pricey! I'm picking up a SX3100 soon, and the dealer quoted me $385 for the PB kit installed. Of course, the kit is just a couple of hoses with caps or quick couplers - no valve included. I told him I'd just get the kit later along with an aftermarket valve, and install the parts myself. Wonder if I'll come to regret it :D
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
121A (A63745)
121A (A63745)
