Cub SLT 1550 Engine Question
   / Cub SLT 1550 Engine Question #1
tillboy2001
I have a CC SLT 1550 with 38 hours on it. It has the 25 HP Kohler Courage 2 cylinder engine. This happens very often - after having used the machine earlier in the day, or when restarting it not long after shutting it off, when I go to start it, this is what it does...
When I turn the key to crank it, it'll turn over a few times and then BAM! it stops cold as it there's too much compression for it to turn over. Then I can turn the key again and it'll start up, usually with a puff of white smoke. Occasionally the white smoke is pretty heavy and smells of engine oil burning.
Any ideas on why this happens? Has it happened to you?
   / Cub SLT 1550 Engine Question #2
Time to return it to your dealer; have him repair it.
   / Cub SLT 1550 Engine Question #3
Check to be sure your oil level isn't too high. It sounds like it is purging oil from the breather up in to the air intake. -Fordlords-
I'll check the oil level first...
One pallet of miscellaneous items (A53117)
One pallet of...
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
1992 MACK RD688S (A53843)
1992 MACK RD688S...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
