cub Lt 1042 clutch wires
   / cub Lt 1042 clutch wires #1
bamaman01
Section Al
cub LT1042
Does anyone know the gauge wire to wire up the clutch? Got a broke one.
   / cub Lt 1042 clutch wires #2
typical elect PTO draws around 4-6 amps - would think 12-14 ga wire should be enuff....
   / cub Lt 1042 clutch wires #3
usually when you pull of the deck,sometime's you need to BACKOFF ,the belt guard to remove the belt if you completely removed the guard but did not install it so the guard goes in the clutch slot the clutch will spin and pull out the wires,if you are lucky you can resolder the wire to make work .12-14 ga should be fine if you need to ad wire
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58216)
2018 LARK UNITED...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2025 SDLC1220 12ft X 20ft Steel Carport (A55974)
2025 SDLC1220 12ft...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
