Cub hydro system
   / Cub hydro system #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
Is there a website with good service info on the Cub's hydro system. My latest 1872 project (auction) is leaking a bit, I believe from the hydro relief valve. I'm hoping to power wash and isolate the source, but then what.
I noticed in the parts diagram there four different relief valves or maybe the ported and non ported serve a different purpose?
I hate oil leaks!
It also wants to creep forward, I guessing some trunnion adjustment is in order?
Thanks,
Curt
   / Cub hydro system #2
You can download the 1862 (very similar model) service manual here:
IHRegistry Home
The hydro creep is due to the linkage to the pump needing adjusting, which is very common on older hydro tractors. The leaks are likely to be your typical seals and gaskets.
-Fordlords-
Dixie Chopper LT2000 Zero Turn Mower (A53117)
Dixie Chopper...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
Landoll Hauloll (A53473)
Landoll Hauloll...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
