Cub GT2554 Deck Problems
   / Cub GT2554 Deck Problems #1
dphillips
I have a Cub GT2554 that I bought last May, and it has 14 hours on it. Recently I tried to mow with it and when I engaged the PTO it would "white smoke" the belt from the engine pulley. I had greased the fittings but it seems that a bearing somewhere in the deck has seized up (It's presently at the dealer's in the shop). Has anyone else had a similar problem, and if so what was the cause?
   / Cub GT2554 Deck Problems #2
Too many possibilities to list! Can you turn the belts by hand? Visually inspect for anything out of the ordinary like a stick binding the belt or something. Remove the belts and check the freedom of movement of each idividual obstacle the belt has. You should have found your problem by then.
   / Cub GT2554 Deck Problems #3
the original query is dated 2007. Where are you digging these old posts up from ?
   / Cub GT2554 Deck Problems #4
Wow. Mr redneck likes digging up the archives!
377854 (A48836)
377854 (A48836)
2019 Toyota Camry Sedan (A48082)
2019 Toyota Camry...
New/Unused 2025 CFG MX12RX Mini Excavator (A48837)
New/Unused 2025...
Komatsu PC138 (A50490)
2015 Ford Explorer SUV (A48082)
2015 Ford Explorer...
2018 Chevrolet Impala Sedan (A48082)
2018 Chevrolet...
