cub cadet zero turn with steering doesn't turn hard left
   / cub cadet zero turn with steering doesn't turn hard left #1
rixtory
Bronze Member
Bethlehem, PA
Kubota BX2200
Hi all - After being on here for over a decade with my Kubota compact tractor - I have moved to a smaller lawn and now have a new cub cadet RZT-s Zero Turn with Steering wheel.. Unfortunately my dealer closed and now I think I have an issue. When turn right, there is no problem, but when I turn left, suddenly the steering wheel doesn't allow my to turn my wheels tightly and go into a zero turn mode. Anyone ever have a problem like this before? It will zero turn to the right but not completely to the left.
Thanks Rick
   / cub cadet zero turn with steering doesn't turn hard left #2
First off check the tire pressures and that the hydro release levers aren't in tow mode. The linkages are adjustable, but they suggest you have the tool kit w/ the alignment bar to do it. I could send you the procedures for linkages if you wanted. I would think that if it worked correct before and it is a fairly new machine that hopefully something came loose or got jammed where it didn't belong. Or take to another dealer.
