Cub Cadet Zero Turn Tank Comerical
   / Cub Cadet Zero Turn Tank Comerical #1
leftybob
Bronze Member
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I purchased this machine last year and I'm trying to find the greese fitting for the mower spindles. I was told they may not have any if they are sealed ball bearings & not roller bearinge like my other mowed decks have. Any one know for sure? I think it is an 02 year model.
   / Cub Cadet Zero Turn Tank Comerical #2
Find the machine's I D plate. Write down the machine's FULL model # and serial number from the plate. Go to this website:PDF Manual Web Archive, enter those numbers. You should be able to download an owners manual and possibly a parts list for that particular machine. From that, you should be able to know for sure about how the spindles are set up.... zerks or no zerks.
Some deck spindles have the zerks up on top, some under the belt/pulley shields, some under the deck itself.
   / Cub Cadet Zero Turn Tank Comerical #3
You might find this link interesting. It's a training manual for the Tank or certain repairs and belt replacements. Bookmark it for sure.
http://service.mtdproducts.com/Training_Education/769-01760/769-01760_SM_MMZ.pdf
   / Cub Cadet Zero Turn Tank Comerical #4
Interesting - Good info, Kid... OP, on Pp 10 of that pdf file there is a pix of a disassembled spindle - magnify it to about 400x and you will see the grease zerk and cast boss on the spindle hsg where it is located.... mebbe that will help you find yers..?
   / Cub Cadet Zero Turn Tank Comerical #6
nice link,thanks def bookmark that one...glad
Better yet, download thePDF file and save it. The link may one day go away. Once the PDF file loads, you should have an option to save it locally.
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
