Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change
   / Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change #1
Rhino35
Independence, KY
2013 Kioti DK 40 SE Hydro and two Cub Cadet riding lawn mowers
I just performed a Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change. This was no fun! I found a great 26 minute detailed "how to" video on YouTube -
- and tackled the job on my 540 hour mower. Never been done before, although I've done regular engine oil and filter changes.
In a nutshell, Mr. What's Broke Today was able to loosen and remove and reinstall, with an Allen wrench, each tranny's "vent" bolt, which is high up on the casing's interior side of the Hydro-Gear. My Hydro-Gear model number is ZH-MGBC-A2GB-26XX. My vent bolt locations were identical. Time for a rant. The engineers who thought this location, amongst various rods and stuff all in the way, and who thought Allen wrench bolts were great ideas should be flogged.
I could loosen the right side, but no way the left side. So I left the right bolt tightened. Somebody told me you can still refill fluid via the reservoir behind the seat (and you'd do this will the vent bolts removed too), but it takes a while. Define "a while".
Happy to. Like forever, at least for the right side. After I drained the fluid by removing each filter I put on new filters, then began the process of putting 4.2 quarts into the reservoir. It drained very slowly. Snail pace. I got a squeezy bulb/tube and began trying to squirt fluid into the forward and aft holes that go into separate hoses to each tranny. I had the mower up on jacks so I rotated the wheels by hand in between forever intervals. After I'd gotten almost three quarts in there I started the mower and tried running the rear wheels. Only the left wheel moved, the right acted like the transmission disconnect had been pulled, but it wasn't pulled. I was stuck. No more fluid would drain.
With the left wheel working and the right not it appeared most of the new fluid had slowly drained into the left tranny. This was pure luck because I could not loosen that vent nut. But I could remove the right - so I did that. This did the trick - the fluid in the reservoir rapidly drained out. I added new fluid until it came out the right vent hole (thanks, Mr. What's Broke Today, for showing how this works. I put back in the vent bolt. Put some more fluid in the reservoir.
Took the mower off jacks and drove it. ONLY the left side tranny was engaged. But the right side was full too. Did I break it by trying to run it with too little fluid?? Visions of a $2,000 repair. I searched the web and saw instructions to pull the disconnect rods back and forth to disengage and engage while running the engine and holding the tranny GO and BACK pedals forward and back. And this fixed the problem.
Hope this helps other DIY's.
   / Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change #2
HG offers a nifty (but expensive) kit for changing fluid, comes with their fluid and filters as well.
   / Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change #3
Yes, I did the fluid change on my trannies a few years back without removing the top vent bolts. I did it during the off season and it took about 2 months to get all the fluid in there using the "let it sit and wait it out method". Ever since I now spend the extra time and effort to open those hard to reach vents. Can get it done in 45minutes that way!
Just did both my ZT2800 and ZT3400 trans this off season. Working like the champs they are this year. Good thing too as the grass is GROWING like crazy with all the rain here in Western Pa this year.
   / Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change #4
If I'm not mistaken, HG sells a kit just for that that contains a new top plug and other acessories.
   / Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change #5
No plug but two filters, 5 quarts of 20W50 and the pump and the hydro adapters to connect the pump hose to.
Sooooo, my neighbor upon hearing this story said, "You should have called me."
Why?
Because I have a rachet wrench with Allen wrench fittings.
Who knew there was such a thing? Not me!
   / Cub Cadet Zero Force SZ Hydro-Gear transmission fluid change #7
Why?
Do yourself a favor and get a set.
I always have Torx bits and SAE/metric hex bits for my 3/8 racket.
Torx bits and SAE and metric hex bits for my 1/4" impact driver
Thanks for the info!
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
1998 Cornhusker Hopper Bottom Trailer (A50514)
1998 Cornhusker...
PALLET OF IRRIGATION PUMPS / WATER PUMPS (A51244)
PALLET OF...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
YALE NR035DANM247F091 WAREHOUSE STAND ON FORKLIFT (A51242)
YALE...
