cub cadet yanmar EX3200 Gauges
   / cub cadet yanmar EX3200 Gauges #1
Nighthawk1169
2009 cub cadet Yanmar EX3200
Hi everyone, i have the same issue with the temp and fuel gauge on Cub Cadet Yanmar EX3200, did anyone ever get this resolved or insight.
very frustrating mine works sometimes and sometimes not. they are both affected
Gentlemen i have found some info on this issue and many members have reported similar issues.
there are three wires going to both temp gauge and fuel level gauge they are RED, Black, and Yellow.
the wires represent the following
Red= 12 volt power
Black = constant ground
Yellow represents variable ground or thru the sender signal.
problem is these gauges are not available independently and come on a printed circuit board panel with both gauges and the tach.
there is a lot of problems with the printed circuit board with microscopic cracks that will fles on bumps or vibrations causing connection and disconnection.
the resolution is a new instrument panel board with the gauges and tach.
Cost is approx $250.00 easy to replace but you will be starting out with a new hour meter as well that starts from zero hours.
I developed this info from a Yanmar america tech engineer.
seems to be a common issue and the stock 45 of the instrument panels.
Hope this helps.
Red= 12 volt power
Hope this helps.
Instrument gauge cluster is part # CY-1A8160-56100
Instrument harness is part # CY-1A8160-56210
   / cub cadet yanmar EX3200 Gauges #6
FYI
This is a pic of the back of the temp gauge on my EX3200.
   / cub cadet yanmar EX3200 Gauges #7
Please see attached pics for testing Monitor panel for 3200
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Ford 8340 (A53317)
Ford 8340 (A53317)
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
