Cub cadet won’t crank
   / Cub cadet won’t crank #1
jlong34016
Cub cadet
2016 cub zero turn won’t crank. Have to jump power to solenoid. All safety switches work. Any ideas?
   / Cub cadet won’t crank #2
trace wiring till you don't find power?
It has one of those $200 computer controllers. Dozen wires.
   / Cub cadet won’t crank #4
check battery, needs to be at least 12.0 but better if 12.6 or higher
check cables while there for corrosion
Check safety switches like under your seat for starters.
Please take a moment to report back. Others will help if you need it.
Please save this as a favorite and report back so others can learn who follow.
thanks and good luck
   / Cub cadet won’t crank #5
PTO switch off ?
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
