cub cadet volunteer keeps stalling going into gear
   / cub cadet volunteer keeps stalling going into gear #1
bebop86
NJ
so my son suprised me and got a 2014 volunteer with only 180 hrs- It starts fine but when you go to put it in gear it stalls- can not get it to run- took spark plug out and completley black- going to replace but any ideas- It has the kohler engine
   / cub cadet volunteer keeps stalling going into gear #2
Hi, you say it stalls after putting in gear? Does it grind the gears to engage? Sounds like the clutch isn't releasing if it is as putting it in gear at an idle does nothing until you give it rpm to drive away. But you say will not run? You can't start them in gear...
   / cub cadet volunteer keeps stalling going into gear #3
Release the Hand Brake.
   / cub cadet volunteer keeps stalling going into gear #4
There is a hand brake lockout switch. If you have already released the handbrake and it still does that I would check the continuity on the switch.
   / cub cadet volunteer keeps stalling going into gear #5
I'm not familiar with the gas models or the newer ones but other than the audible buzzer warning for the handbrake there's nothing stopping the engine by having it in gear with the handbrake applied. That would actually be a real pain from my experience but I'm not saying it might not be so, just questioning.
yes we figured out the handbrake issue- thanks so much
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
