Cub Cadet voltage regulator adjustment
   / Cub Cadet voltage regulator adjustment #1
zilla24
I’m having some charging issues with my old cub cadet model 86 with a 10hp Kohler. It wasn’t charging, with a meter hooked to the battery at full throttle it was outputting 12.5 v. I bought and replaced the voltage regulator, it is now charging at 16v! Is there an adjustment procedure I need to follow to get it charging around 14.5v?
   / Cub Cadet voltage regulator adjustment #2
No. Output is dependent on the regulator you have and level of charge.
   / Cub Cadet voltage regulator adjustment #3
I think those had a mechanical regulator, which can be adjusted by varying the gap on the points. that generator is also used as a starter, if that's an IH Cub Cadet, they were really well made machines!..BTW, 13.8V is much safer for the battery, less water is lost..
It is an International Cub Cadet, I think its about a 1974. I'm fixing it up for my daughter to "help out around the house" i.e. take the dog for a ride in a wagon. I found some information about adjusting the points gap, set it to .020" which unfortunately didn't help. Sending the regulator back to try another, hopefully the next one is good.
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
202473 (A54757)
202473 (A54757)
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
