Cub Cadet Starter Drag
   / Cub Cadet Starter Drag #11
We have a Cub Cadet 1050 mower. When ever we try to start the starter drags. It has been this way since new. We took it back to the dealer and they would just put a new battery in it. If I just hold the key it will start but this is not normal. it is an issue of the starter not turning. The problem would never go away. Does anyone have a fix for this. Loose ground wire, something????
After the dealer put a new battery in it. Did it work ok then? Have you ever charged the battery up and had good results starting?q
   / Cub Cadet Starter Drag #12
I have a 1046 with the courage 22 hp that has done the same thing since it was new. No power washer or water has been on the starter
   / Cub Cadet Starter Drag #13
I don't know if this is any cause to or fix of the dragging starter I have, but here we go.
Since my last post about a 1 1/2 months ago, I began using Sta-bil faithfully in the fuel. At first, for the first few times the starter would drag and then it stopped. Now, you turn the key and it fires right up.
Don't know. I really don't understand how it would help it, but it did. Thank goodness.
Might want to give it a try for a $5 fix.
   / Cub Cadet Starter Drag #14
you all keep going on with starter prob's it is not. i have been a cub dealer for over 30 yrs if a higher cranking battery does not fix it then set the damm valves ...period.if that does not fix it then contact kohler about replacing cam,briggs had the same prob with single cylinder intect engines if setting the valves in this engine did not fix the prob then, replacing the cam did . briggs was aware of this prob with there cam's
   / Cub Cadet Starter Drag #15
Gladiator,
Nice to know your work history. Did you ever think the mower is out of warranty. What do you suggest then.
Thanks for your humble reply.
   / Cub Cadet Starter Drag #16
fix it.warrenty does not cover valve setting anyways......lol
Gladiator,
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
15ft Batwing Rotary Brush Cutter Tractor Attachment (A55851)
15ft Batwing...
TANK MANIFOLD (A58214)
UNUSED FUTURE LASER LEVEL W/ TRIPOD (A57193)
UNUSED FUTURE...
Peterbilt 377 Semi-Truck (A55315)
Peterbilt 377...
2020 Hino 195 20ft. Electric Box Truck (A55852)
2020 Hino 195...
