cub cadet sltx 1054 thoughts?
   / cub cadet sltx 1054 thoughts? #1
854run
mid-west
What are your thoughts on buying a cub cadet sltx 1054? Live on about 1.5 acres or relatively flat land with only minimal inclines. I would also use the machine to plow 200+ foot drive
   / cub cadet sltx 1054 thoughts? #2
Outstanding machine for mowing. Very comfortable and maneuverable. I know people use them for plowing and snowblowing, but I personally wouldn't push it hard with those tasks. The belt drive and transaxle would be the weak spots for those tasks. These transaxles can also overheat if you've got long stretches of heavy inclines to mow.
Joel
   / cub cadet sltx 1054 thoughts? #3
This will probably put me in the "mower snob" category... but, here is my opinion.
For anyone who actually wants to use their lawn mower for anything else than mowing a very small yard... the 1000 series should be avoided. It truely is "bottom of the barrel". For the price, you can probably either get something better from another brand or the same quality for less.
The 2500 series is around 50% more (msrp), but gets you the shaft drive that is important to some people. Plus, I'd argue its better suited and built for non-mowing activities like... snow pushing.
On a related note, I think using a small lawn mower for snow pushing is probably not the best way of doing things. If you only get 2-3" of snow... well, then it's probably fine. I have a Sc2400 and I use that to push snow with the FEL and last winter, it sure had it's *** full trying to push all the snow we got. I couldn't even imagine trying to push all that snow with a much smaller lawn mower (less than half the weight) without a locking diff and without 4wd. On the other hand, a small lawn mower with a snow blower would be fine, I would think.
This is just my opinion... of course, you can do with it what you will.
1454 (A57192)
1454 (A57192)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
