Cub cadet rzt electrical issues
/ Cub cadet rzt electrical issues #1
Kylelangereis
Cub cadet rzt 50
Started out as a weak crank. Replaced bad battery that wouldn't hold a charge, also replaced the starter solenoid. I have 12.5 volts at the battery and at the post on the solenoid. I have 10.5 volts at the connection on the solenoid coming from the switch when the key is turned. If I turn the key though nothing happens. If I cross the posts on the terminal the motor will roll over but I cant get any spark. Absolutely suck at electrical so I'm at a loss. Any help much appreciated.
/ Cub cadet rzt electrical issues #2
No spark is a safety switch. I'd check the ground connection since solenoid doesn't engage with key. You'll have safeties on the drive handles, parking brake and seat switch. Make sure they all work and if still nothing, I'd replace the PTO switch. Safeties and PTO switch were the most common problem on ZTs. Good luck.
/ Cub cadet rzt electrical issues #3
I like to start at the source. Clean your battery terminals. Clean the inside of the connectors. Replace connectors and tighten firmly - they should not move. Trace your ground lead to the point where it connects to the frame. Clean surfaces well and be sure connection is tight. I'd begin troubleshooting from that point. Of course from there none may be required.
/ Cub cadet rzt electrical issues #4
MTD (aka: More Tools Desired) uses the cheapest electrical components they can buy so anything electrical is suspect. Think I'd make a jumper wire and start jumping the switches to find the bad one after cleaning all the grounds and battery terminals.
1972 CHEVROLET C/60 - 18' GRAIN DUMP TRUCK (A64276)
1972 CHEVROLET...
MASSEY FERGUSON 135 TRACTOR (A64276)
MASSEY FERGUSON...
Deutz D3006 Tractor (A62613)
Deutz D3006...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
