Kylelangereis
- Joined
- May 2, 2021
- Messages
- 1
- Tractor
- Cub cadet rzt 50
Started out as a weak crank. Replaced bad battery that wouldn't hold a charge, also replaced the starter solenoid. I have 12.5 volts at the battery and at the post on the solenoid. I have 10.5 volts at the connection on the solenoid coming from the switch when the key is turned. If I turn the key though nothing happens. If I cross the posts on the terminal the motor will roll over but I cant get any spark. Absolutely suck at electrical so I'm at a loss. Any help much appreciated.
