Cub Cadet RZT 50 - Ongoing Reviews
   / Cub Cadet RZT 50 - Ongoing Reviews #101
Just thought I would jump in. I have one a RZT 50 with 3,500 hours on it now. Only issues are normal flat tires. A couple of belts and that was due to leaves backed into the deck ,2 batteries and one blade spindle. I change the blades each season. I am not very maintenance oriented either. I change the oil once a year and that's it. I did change the fuel filter once. Bought it in 2005 and just power washed it for the first time yesterday. Looked like a new mower now.
That's around 425 hours per year for a residential grade mower. wow! I average around 55. Pressure washing is dangerous. You can get water into the hydro gear drive vents where it will cause drive problems.
   / Cub Cadet RZT 50 - Ongoing Reviews #102
just got a 7 year old rzt 50. mow my 4 acres with it on Sunday. has 138 hours, am so happy nice cut took 3 hours as compared with more than 8 hours with my old craftsman tractor with 44 in deck.
   / Cub Cadet RZT 50 - Ongoing Reviews #103
Can I get some input?
I am looking to buy a 2008 50 in. zero turn with 550 hrs.
Original owner is selling it, no major repairs to it, she says.
I drove it, it pulls a little to the right, but the Kawasaki engine started right up. Engine seemed to run well.
I'm just concerned about repairs, she's only asking $450 for it. It seems like if it were to have major problems it happens around 200 hrs. based on reading this thread.
Is this a really good deal and I'm being too cautious?
Thanks
Mike
   / Cub Cadet RZT 50 - Ongoing Reviews #104
Mike,
What are you waiting for? Buy it!
You've read the reviews, too many of them for sure, but at this price it would be a good deal. Adjusting the linkage for the one arm should bring the straight ahead steering back and is easily accomplished. As for buying a lemon that lets you down, ...if that happens, sell it for parts on this forum and recoup more than you spent buying it. Then again, as some reviewers have said in this thread ... "it has 3500 hours with just new blades, two flat tires and belts to fix". You may have found a gem.
Gene
   / Cub Cadet RZT 50 - Ongoing Reviews #105
Has anyone taken one of these transmissions off and rebuilt it ? I have and RTZ 50 and the LH is starting to lose power after a few minutes. Looks like I can get all the parts (Pumps, motor, swash plate) to rebuild it just wondering if anyone had taken one apart and what they found wrong. I am going to try the 47" belt and fluid change first, just looking at options other than buying a new unit. It just seems if the unit works for a few minutes the guts can't be too bad and should be repairable.
   / Cub Cadet RZT 50 - Ongoing Reviews #106
Do you have the Hydrogear manual? If not I can email it to you. Did you try the air purge procedure? I had power lose after 10-15 minutes as well. I did the fluid change and I feel mine has returned to near normal operation so definitely give that a try.
   / Cub Cadet RZT 50 - Ongoing Reviews #107
Yes I have the Cub Cadet and Hydro Gear manuals. I am going to try the fluid and belt change to see how that does and I will have to purge after the fluid change so we'll see how it goes. Did you use synthetic fluid or dino ?
   / Cub Cadet RZT 50 - Ongoing Reviews #108
I used full synthetic 20W50.
   / Cub Cadet RZT 50 - Ongoing Reviews #109
Before you dig into the Hydro, you may wanna make sure the drive belt is in good shape - weak left side is one of the symptoms of a belt that's starting to slip - due to the geometry, the left will slip first. Just sayin', a belt is cheaper/easier than the tranny... Steve
   / Cub Cadet RZT 50 - Ongoing Reviews #110
No question there, I went out yesterday and bought a couple quarts of synthetic 20W50 and a new 47" belt. I'm goint to try that on Saturday before I even think about tearing it apart. I just have not seen a single instance of someone taking one of these apart and changing out the motor/pump/thrust bearing inside and having it work. It looks like I could replace most of the hydraulic "guts" for around $200 or so instead of $500 for a new unit. I really don't see what else would be failing in it with it losing power after a few minutes, all the gears, seals and shafts are good. I would change out the filters and such if I went inside, just looking for a success story somewhere to make me feel better about trying. The unit doesn't look that complicated to dissasemble.
MAHINDRA 6500 TRACTOR (A57192)
MAHINDRA 6500...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A57192)
(INOP) 2015 FORD...
(2) UNUSED 18.4-30 TRACTOR TIRES (A57192)
(2) UNUSED 18.4-30...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
