Cub Cadet rops lighting project
   / Cub Cadet rops lighting project #1
cubowner
Kubota BX24
I finally have gotten to about 85% install on my lighing project.I installed two 35 watt blazer lights and 2 hazzard lights along with the the switches. I still have to install some type of reverse lights. Any sugestion or comments?
   / Cub Cadet rops lighting project #2
Guess it depends on how you use you stuff. Have been thinking about some lights on the ROPS, but worried about knocking em off while clearing woods. Considered putting them inside the ROPS to help them live longer. If you do any clearing, think they might be subject to damage from limbs etc.
I did try the lights inside but there was not enough head room. Also tried on top of the rops but the unit would then be to tall to fit in my garage door. I am looking for some type of cage to put over the lights. But i can't find someone who sells that type of item.
   / Cub Cadet rops lighting project #4
How did you attach the brackets to the ROPS? I didn't see a fastener so I'm guessing JB Weld epoxy?
I actually spot welded them in place at low heat.
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
6ft Rotary Brush Cutter Tractor Attachment (A55851)
6ft Rotary Brush...
205882 (A57192)
205882 (A57192)
Deere 331G (A53317)
Deere 331G (A53317)
Hustler 62in Zero Turn Mower (A55851)
Hustler 62in Zero...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
