cub cadet reverse PTO shutoff
   / cub cadet reverse PTO shutoff #1
ryan357
I've got a Cub Cadet 1517 that has the typical PTO shutoff when you put it in reverse. I'd like to disengage that so that I can cut in reverse. I'm told it's easy but can't find a wire or anything to do that. Any help?
   / cub cadet reverse PTO shutoff #2
Post this same message in the Cub Cadet forum, they will tell you where to look.
   / cub cadet reverse PTO shutoff #3
Not sure if the 1517 is included, but there have been at least a couple rather recent threads on the same subject in the cub cadet discussions. So, you may be able to run a search in the CC forum and find what you need, or like Inspector507 wrote, you may have a bit quicker results posting there.
However, if I may add, it may save confusion asking a moderator to move it instead of having the duplicate post. Maybe you wanted it under Customization for some reason, else if you want it moved:
Make a reply to any of the posts [now 3] in this thread, and write something like "If this belongs in another forum like Cub Cadet, could a moderator please move it." If you need it expedited or you really blundered [certainly not the case here], then you can hit "notify moderator" on the post. From what I've seen, they are often very quick to help out.
Good luck finding the answer; can't remember if it was CC or another brand, but I remember reading about several models that can be "cured" by simply bending a little steel finger [located under the reverse postion] so it won't contact the switch. Have fun! /forums/images/graemlins/cool.gif
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
Deere 350G LC (A53317)
Bobcat T590 (A53317)
1999 Tropi-Cal Class A Motorhome (A55853)
1999 Tropi-Cal...
2014 BMW X3 XDrive28i AWD SUV (A55853)
2014 BMW X3...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
