Cub Cadet PTO fluid change
   / Cub Cadet PTO fluid change #1
Djones2556
Gt2100 cub cadet
Have a GT 2100 cup cadet riding mower change filter and fluid yesterday drove fine before we changed after we change the fluid will not engage in gear anyone have any suggestions I have tried pushing it to bleed the system still no luck
   / Cub Cadet PTO fluid change #2
Do not push to bleed system. What kind of fluid and filter did you use? You should use Cub Cadet Drove Fluid Plus Part and a Cub Cadet Tranny Filter Part #
923-3014Hydraulic Filter
737-3120 quart fluid (Hydro) Holds 5.5 quarts
The Cub Cadet GT2100 has a BDU10 Hydro Gear Hydostatic Transmission. To bleed air from the transmission, pull the transmission release lever on the rear of the tractor and lock it down. (this puts the transmission in By-pass mode (neutral). Sit on mower and start the engine then throttle to halfway. Press on the forward drive pedal slowly for a few seconds then press on the reverse drive pedal slowly for a few seconds. Continue this back and forth 3 or 4 times pressing the drive pedals completely down and the air should be purged from the tranny. Switch engine off and release the transmission by-pass rod. Restart your engine and depress forward or reverse pedals. If the mower does not move, you have OTHER problems, maybe Filter or Fluid brand.
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
JOB BOX W/ 100K X 20' NYLON SLINGS (A54757)
JOB BOX W/ 100K X...
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
