cub cadet powershaft 6284 split drive shaft repair
   / cub cadet powershaft 6284 split drive shaft repair #1
benson1
elk wa
benson1@q.comHave had this fixed 2 times and is broke again .I think they have wrong drive shaft It seem to short. Where the split is attached washers are used to make it further apart>Was done at a Cub Cadet
service dealer ?Does anyone know the length of the short shaft ?Or have any idea or comment Cadet
   / cub cadet powershaft 6284 split drive shaft repair #2
This one might be a good one to ask in the Cub Cadet forum
thank you
View attachment 395218View attachment 395219View attachment 395220View attachment 395221View attachment 395222View attachment 395223
Does anyone have any Idea Please :confused:
   / cub cadet powershaft 6284 split drive shaft repair #5
You might know what broke and was fixed but it's not obvious from either your post or your pics.
the short shaft does not seat all the way on the rear splines. See my finger pointing. Where the 2 meet many washers were used to space it out. Does not seem right. Do not know how to explain any better sorry. Thanks.
   / cub cadet powershaft 6284 split drive shaft repair #7
If the splines don't engage far enough, I'd make the shaft longer or buy a longer one. I'm a machinist, so I'd get rid of all the washers and spacer plate. I'd cut the shaft in the middle and weld in a piece of tubing to make it the right length. If you can't do it yourself you'll have to have a machine shop do it. Would be an easy job.
The alternative would be to make a thick spacer plate to replace the washers and existing spacer plate and make the splines engage farther. It might be easier to assemble with this method.
   / cub cadet powershaft 6284 split drive shaft repair #8
Where did it break?
The short shaft was replaced at dealer. Seems to short to me. It is not broke apart now. But bangs all over and broke u shaped guard. That was welded over the shaft.So it is actually still together in pictures.
   / cub cadet powershaft 6284 split drive shaft repair #10
I can't see it in the pictures, but is there a u joint at each end of that shaft?
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
