Cub cadet m60 zero turn isnt starting but is cranking
   / Cub cadet m60 zero turn isnt starting but is cranking #1
magoo3600
louisville
m60 cub cadet
Im out at my moms working on her mower as she ran it out of gas and now the mower wont start, ive put gas back in the right tank but also tried the left tank witch is full of gas i have blew out all of the lines to make sure she didn't suck anything up into the lines and everything seem fine, but the motor just sits there and cranks and wont start. and when i turn the key to the on position to prime the fuel pump i just hear a clicking sound coming from it.
Any ideas would love some help
thx matt
   / Cub cadet m60 zero turn isnt starting but is cranking #2
remove engine air cleaner. spray a cuppla shots of rattlecan carb cleaner down into carb throat while assistant is cranking engine. If engine pops and attempts to start, then you do have a fuel delivery problem. if nothing, then you have an ignition or internal mechanical engine problem (more likely ignition, kill wire or safety switches). Test and let us know.
   / Cub cadet m60 zero turn isnt starting but is cranking #3
thx matt
I agree with rcbe's idea. My 3235 has the rocker arm actuated diaphragm fuel pump and last summer I didn't notice the low fuel light and ran out of gas. It took me quite a while to get it running again. I cranked and cranked and finally sprayed starting fluid into the carburetor. I had to do this several times, with the engine running a few seconds each time until it finally primed the pump and continued running.
Bob B.
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
2018 HINO 268 REFRIGERATED BOX TRUCK (A57192)
2018 HINO 268...
UNUSED FUTURE MINI QUICK COUPLER (A57193)
UNUSED FUTURE MINI...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2016 Caterpillar 349FL Hydraulic Excavator (A53421)
2016 Caterpillar...
