cub cadet m48 shut off when engaging blades
   / cub cadet m48 shut off when engaging blades #1
Tm48
Indian Trail
cub cadet commercial m48 tank
Hi tm48 here have a question about my cub cadet m48 tank 20 hp honda v twin Recently i was cutting and the mower gradually cut itself off almost like someone pulling the spark plug cable off no sputtering just a smooth and slow stop i reset everything like starting for the day and cranked it back up when i engaged the blades it bogged back down and started to cut off a i disengaged the blades and it returned to a smooth run. I let it idle for a few minutes then re engaged the blades it ran and cut for about 5 min then it started to bog down again i disengaged blades again and again it returned to a smooth run. Ant ideas
   / cub cadet m48 shut off when engaging blades #2
Welcome to TractorByNet!
We moved your thread to the Cub Cadet Lawn & Garden forum. :)
   / cub cadet m48 shut off when engaging blades #3
It could be the micro switch in the seat. If it fails so it thinks you are no longer in the seat, then it will shut off the engine just like it does if you try to dismount with the mower running. I would jump that switch and see if it solved the problem, then buy a new switch for safety.
Since I am not all that mechanically inclined when you say jump that switch would that be unplugging it
PORTABLE SPRAYER (A57192)
PORTABLE SPRAYER...
CFG Industrial MH12RX (A56469)
CFG Industrial...
UNUSED PABREAK CR720 - 74" VIBRATORY ROLLER (A57193)
UNUSED PABREAK...
Hydraulic Press (A56469)
Hydraulic Press...
9000 (A47477)
9000 (A47477)
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
