The filter doesn't necessarily completely fill up. You're right that you need to have "free" flow to the pump, but the pump is a little diaphragm and check valve and WILL provide some "suction". I have tested the diaphragm pumps before by removing them and providing pulses on the pulse line via mouth, just using water as a working fluid (make sure to blow it out thoroughly afterwards.
The solenoid does shut off fuel to the carburetor (actually, shuts off the main jet). It just unscrews from the carb bowl.
- Jay
- Jay
