Oil & Fuel Cub Cadet LT 1046 - Fuel Leak
   / Cub Cadet LT 1046 - Fuel Leak #1
jpmorgan12
Charlotte, NC
I noticed a strong fuel smell coming from my 4 year old Cub 1046. Looked underneath and saw a slow leak where the rubber fuel line meets the tank.
Thought (hoped) it was the fuel line, so I snipped off about 2 inches from the end, reconnected, and still had a slow leak.
Through some basic troubleshooting, it appears as if the bottom of the tank has a slow leak around the nozzle that you connect the fuel line to.
1) Have any of you ever heard of a Cub tank leaking? It has been fine for 4 years, so it just started.
2) Is it difficult to replace tank? I found the part online for about $100.
3) Any other ideas? Am I heading down the wrong path?
Thanks
   / Cub Cadet LT 1046 - Fuel Leak #2
You might be able to repair the leak. Drain the gas and let the tank dry good. Check the automotive section at Walmarts or go to an auto store like Autozone and find an epoxy for plastic fuel tank repair or one that is gasoline resistant. If it don't wok then you can buy the new tank.
Bob B.
   / Cub Cadet LT 1046 - Fuel Leak #3
JP Did you try replacing the hose clamp at the end of the hose where it goes over the tank nipple? 2 part epoxy will do the job...and the price is right. I've used a 2 part epoxy called 'Marine Tec' to repair a tank leak and it's held up for 6 years or so.
The 2 part epoxy for fuel tank repair at Autozone did the trick. No more leak! Thanks for the tip.
   / Cub Cadet LT 1046 - Fuel Leak #5
If it is palstic you can take it to a radiator shop most can weld plastic
Takeuchi TL10V2 Skid Steer, S/N 410002082, Kubota Diesel Engine, Joy Stick Operating Controls, (A59076)
Takeuchi TL10V2...
(INOP) HONDA RIDING MOWER (A58374)
(INOP) HONDA...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
2010 FORD F-150 (A58214)
2010 FORD F-150...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
