cub cadet kawasaki carb prob HELP!!
   / cub cadet kawasaki carb prob HELP!! #1
rockinm
i rebuilt my carb on my cub cadet kawasaki FH500V 17hp and now it acts like it is getting to much gas. it runs pretty well for a little while then dies and seems to run better under a load and thats why i think im getting too much fuel. I believe i just need to adjust it but cant figure out how.Ive adjusted and adjusted until i think i just got everything out of whack?! please help! thanks and God bless, Gary(rockinm):confused2:
   / cub cadet kawasaki carb prob HELP!! #2
Welcome to TBN :thumbsup:
If you are getting to much gas then spark plugs will be black. If too lean then they will be white. Correct mixture will be light tan. Check air cleaner/filter to see if there is a need to replace, check choke to see if it is completely open, check float valve to see if stuck open or any junk.
Post in Lawn tractor forum for more ideas:D
2018 Toro Zero Turn Commerical Mower (A50322)
2018 Toro Zero...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
IH 735 5 Bottom Plow (A50515)
IH 735 5 Bottom...
2024 KRUZ Ravens Tri Axle Dump Trailer (A47384)
2024 KRUZ Ravens...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
