Cub Cadet hydrostatic drive a no go
   / Cub Cadet hydrostatic drive a no go #11
I sold my JD D130 after 150hrs. I don't have the time for weak machines. Mow the lawn with my BX now.
   / Cub Cadet hydrostatic drive a no go #12
The release rod attaches to a lever. Make sure that lever isn't bent and that it moves freely. The bypass allows you to manually move the tractor when the engine is not running. If you can push the tractor, the lever that rod attaches to is jammed in the release position or there's internal damage to the bypass valve. If that's the case, I'm afraid you're SOL. There are no internal parts sold for the transaxle. It has to be replaced in whole. Which appears to be in the $600 range. :thumbdown:
Update: There are parts for that T/A. Looking at the parts breakdown, there is an internal lever and valve (#47 & 48) that are actuated by the lever on the outside. Bottoming out may have bent the internal lever or the outside lever has moved on the shaft. I still think the problem is in the release mechanicals.
   / Cub Cadet hydrostatic drive a no go #13
These are the parts associated with the release (bypass).
   / Cub Cadet hydrostatic drive a no go #14
Could any one send me the information on how to remove the hydro drive transmission on my RTZ 50 cub cadet zero turn. I have 2 new ones and I need to change them out. I would certainly appreciate it.
   / Cub Cadet hydrostatic drive a no go #15
look under your tilting seat for the ID tag for your machine - s/b a model # starting with "17"... get that full number and the serial # - go to this website: PDF Manual Web Archive , enter that data and you _may_ be able to d/l a service manual for the RZT series (yeah, a long shot..) good luck.
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
2014 AMERITRAIL TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2015 CATERPILLAR  XQ30 GENERATOR (A58216)
2015 CATERPILLAR...
NEW PIG DRM654 HYD WASTE COMPACTOR (A58376)
NEW PIG DRM654 HYD...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
