Cub Cadet hydrostatic drive a no go
   / Cub Cadet hydrostatic drive a no go #1
DeereJerry
Forest Hill, Maryland
Cub Cadet / SLT 1550
I have a 2007 Cub Cadet SLT 1550 with 621 hours on it. It has performed beautifully until this fall when I rode over a 4" deep tire impression that was made in my front yard. When the right rear tire dropped into the 4" ditch, the engine continued to run but the hydro drive stopped working. no forward or reverse. Relocated tractor to driveway and check for damage and/or leaks. none were apparent. Any ideas?
   / Cub Cadet hydrostatic drive a no go #2
Jack up the rear and see how the wheels turn. (Only one or in reverse) then follow up on the rest of the drive line.
   / Cub Cadet hydrostatic drive a no go #3
Start with the easy stuff; Check the drive belt-On/off or broken. Check the hydro bypass rod and see if it's locked/jammed in the release position. Ditto what Egon says. Check the axles.
   / Cub Cadet hydrostatic drive a no go #4
That hydro bypass rod runs under the axle on the right hand side. I bet it's bent and jammed in the release position. Check that first.
left wheel rotates backwards, right wheel rotates forward.
Checked drive belt - good no issues. Hydro bypass rod is not bent but is loose. Both rear wheels turn wit or without bypass engaged
   / Cub Cadet hydrostatic drive a no go #7
Not familiar enough with the tractor to speculate farther.
   / Cub Cadet hydrostatic drive a no go #9
Is that a big box store tractor or a professional model?
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
