Cub Cadet Hydro 1210 - Transmission Issues
   / Cub Cadet Hydro 1210 - Transmission Issues #1
WrongwayJ
Cub Cadet 1210
I have a Cub Cadet Hydro 1210 /Model 148-620-100 and the transmission seems to be having a problem. It seems to be whining/ straining when going up an incline? The top two bolts on both sides of the housing assembly (where the axels are attached - 2 bolts on each side) will work themselves out and I have to tighten them back up every time I run it. Reverse is slow and the entire housing seems to have transmission fluid all on the outside of it?
I am about to change fluid, filter and check the hydrostatic linkage.
Any and all help is most appreciated.
   / Cub Cadet Hydro 1210 - Transmission Issues #2
You might try putting some LOCKTITE on the bolt threads to see if that will stop them from loosening. The Whining/straining sounds like it's probably low on fluid after all the leaking.
Bob B.
Bob B.
Thanks Bob. I will try the Locktite on the bolts. What is driving me crazy is the dipstick says it is ok, but maybe not. I bought this CC 1210 used about 2 summers ago and have been slowly updating this monster. What I mean is that it wasn't Garage kept. Again Thanks.
Do you recommend using a non-Cub Cadet fluid?
   / Cub Cadet Hydro 1210 - Transmission Issues #4
Sounds like you have a Tuff Torq tranny. They put them in many differnet brands...including John Deere.
I have a JD LA140. Tranny whines like a power steering pump. Won't climb hills anymore.
Great something to look forward to. I am going to research the tranny this weekend when I change the fluids and filter. thanks for the info.
   / Cub Cadet Hydro 1210 - Transmission Issues #6
The leaking could be the relief valves on the top of the transmission (under the center housing cover) as over time the o-rings degrade and also dirt/debris get in them. If these are the culprit you can clean them and reinstall but most replace them ($60+ea).
I ran non CC fluid and it whined a LOT more, versus the Hytran CC fluid. Also use a CC filter as some filters look the same but the internals are different and wont work. There should be a drain plug in the bottom of the tranny.
As far as the bolts I have never had an issue with my CC1811 loosening - you might find there are some other loose bolts causing this - i am no help on this issue.
At the end of the day I would clean up the tranny, then change fluid and filter and this might solve your problem..
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2015 Ford F-250XL (A53314)
2015 Ford F-250XL...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
John Deere 3025E (A53314)
John Deere 3025E...
2018 FORREST RIVER CRUISE LITE CAMPER (A55745)
2018 FORREST RIVER...
