Cub Cadet Homemade Front Loader Finished
   / Cub Cadet Homemade Front Loader Finished #1
chevyzr2s10
PA
1985 Cub Cadet 1204
I just thought I should share some pictures of my front loader project that I recently finished. I got most of my ideas and information from the people on tractorbynet and appreciate all of the help.
The tractor is a 1985 Cub Cadet 1204 that I got for free with 600 hours on it. I got most of the hydraulics from the Surplus center. Most of the steel was from my own scrap collection except for a few pieces I had to purchase.
The hydraulic reservoir is built in to the main support of the loader arms and the pump is mounted directly to the front of the engine. The hydraulic lines are a combination of hard steel lines with compression fittings and Synflex thermoplastic hose. I used 3/8" hose because I got all of the hydraulics made for free at my work and that was the smallest that they had.
The loader works extremely well. I filled the tires with about 70lbs each of antifreeze and added a weight box filled with about 300lbs of steel scrap metal. I also have an additional 100lbs in wheel weights I will add later.
With the filled tires and weight box and a 250lb driver it can lift about 500lbs in the bucket. I have successfully tested it by scooping full buckets of gravel and dirt.
So far this has been very handy around my house. I have used it to move some firewood around as well as remove and reinstall a 4 cyl engine from my S10.
Some of the improvements for the future will be to add power steering and move the front axle forward by about 6 in to add more capacity. Also I would like to find some lug tires to give it more traction.
Please comment and ask any questions you like.
More Pictures
Still More Pictures
   / Cub Cadet Homemade Front Loader Finished #4
Really enjoyed the pictures of the build. Thanks for sharing your experience.
   / Cub Cadet Homemade Front Loader Finished #5
chevy,
That is an amazing project. Very nice work. I would someday like to be able to do metal work like that.
Thanks for sharing.
   / Cub Cadet Homemade Front Loader Finished #6
Looks good! I have a question, though. More of a general FEL design than your's specifically. Why does everybody seem to build them so the bucket is so far from the front axle? It seems like it would be able to put more downforce (if needed) into the work if it was closer. It would also shorten the overall length. Is it just because it has to reach that far to get the height?
Dave
   / Cub Cadet Homemade Front Loader Finished #7
Great job! I too was wondering about the bucket being that far out in front of the axle.
   / Cub Cadet Homemade Front Loader Finished #8
That is a neat, well thought out project. I noticed in your shop you have both stick and mig welders. Just curious, is the mig 110 or 220 volt? If 110, how do you like it?
   / Cub Cadet Homemade Front Loader Finished #9
Nice work and thanks for the pictures.
Well equipped workshop too.
   / Cub Cadet Homemade Front Loader Finished #10
Whatego & Mjncad,
I would guess that this is for height. I know that the Woods loader on my B7100 stuck out quite far, compared to the Kubota loader on my B7610. The Woods had a max height 15" higher, which I miss when trying to dump brush and other debris on the back of a truck (the forks are 42" long).
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
STORAGE FEES (A53426)
