cub cadet charging system upgrade?
   / cub cadet charging system upgrade? #1
zepplin454
pelham,nh
Cub SLTX 1050
i have a 2010 cub cadet with a 25 kohler courage. i want to upgrade the stock 15 amp charging system to 25 or so. im running a bercomac snowblower with electric lift and chute controls. it uses alot of power when using the winch and dont want to kill another battery this winter.
   / cub cadet charging system upgrade? #2
Some of these engines came equipped with 25 amp charging systems according to the Kohler Courage service manuals.Sounds like you could swap out the necessary parts with the coils with more capacity and would probably require other parts also.
I am attaching a link to the Kohler site for further study. Might be expensive but can be done.https://www.kohler-engine-parts.ope...-manuals/free-kohler-service-manual-downloads
   / cub cadet charging system upgrade? #3
Probably the most economical way to reach your goal would be to use a DC to DC converter. Call these people and discuss your objective with them. 12v input, 16v output 260W DC/DC converters 700 Watts peak from PowerStream. They probably will be able to prove the correct path for you to follow.
Company Information:
PowerStream Technology
1163 South 1680 West
Orem UT 84058
USA
Phone: 801-764-9060
FAX: 801-764-9061
   / cub cadet charging system upgrade? #4
Orem UT 84058
USA
Phone: 801-764-9060
FAX: 801-764-9061
Not quite sure why you're suggesting that, it would not help. :)
found a 25 amp upgrade kit online. comes with regulator, stator and some other parts. just need to make sure it fits my motor.
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A55315)
2018 Cadillac...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
(3) 12" X 30# X 14' (1) 12" X 30# X 120.5" (A57192)
(3) 12" X 30# X...
