Cub Cadet Challenger 550
   / Cub Cadet Challenger 550 #1
DB Pilot
SW, New York
Case Farmall 65A, L3800 Kubota, BX2200 Kubota
Have been having a annoying problem with our 2020 challenger 550 since we bought it last year. Sometimes when shifting into gear either forward or reverse there is a grinding (sounds like a chain slipping) before the machine is fully in gear. I do not find a chain drive system so I assume it is gear driven? Then the gear, belt or chain grabs ahold and the machine jumps ahead or back, but operates just fine after that. Most times it shifts smoothly and works as it should.
We have tried pushing on the brake harder when going from forward to reverse and being very gentle with the gas pedal. That doesn't seem to matter so at random times the problem reoccurs with the passengers feeling a whiplash type surge.
The other problem is half the time you cannot get into park without moving the machine alittle until gears line up better and you can get it into park.
Wondering if any other owners have found these problems or know whats wrong.
Spoke with dealers mechanic today and explained that my machine does not go into gear until after the gas pedal is pressed. Again only occasionally. His first response was that this was normal. Also with Polaris utv's as they both are belt driven. This was said in front of another mechanic and their boss. A friend of mine also has a Challenger 550, today he drove mine and experienced the belt slippage. Told me he has never experienced that on his machine. I don't know guess I'll drive it til it breaks!
Found another Cub Cadet Challenger Dealer about a month ago. 25 miles from the dealer I originally bought it from. Who agreed to look into the Challenger 550 problem. Guess what, their was a recall on these machines in 2019. Seems the transmissions on some of these machines suffer from internal rust, big time. This causes bearings to wear out quickly as well as difficulty in shifting.
After a year of being ignored by the original dealer and numerous phone calls to CC by my new mechanic CC did begrudgingly honor their warranty. I now have a new bearing, cable, transmission face plate and a smooth shifting/running UTV.
Also found out that these machines must be registered with CC in order to be warranted. New mechanic has done that for me too.
2019 Toyota Rav4 LE Hybrid AWD SUV (A55853)
2019 Toyota Rav4...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2008 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
