cub cadet 7265 rear work light
   / cub cadet 7265 rear work light #1
KThandy
Cub Cadet 7265
Would like to put a rear work light on a 7265. Would appreciate info. for doing this. Thanks.
   / cub cadet 7265 rear work light #2
</font><font color="blue" class="small">( Would like to put a rear work light on a 7265. Would appreciate info. for doing this. Thanks. )</font>
You might look at the Parts/Repair forum. There have been several threads there which can point you in the right direction.
   / cub cadet 7265 rear work light #3
Here is a link to a discussion on this very topic. The tractor discussed was a different brand, but the concept is the same.
Rear Work Light discussion
I installed a SPEAKER 900 worklight on the back of one of mine. It cost about $35 if I recall correctly. The light housing is weather proof and it has a built in water proof H.D. switch. It only required 1 wire to be connected to a positive run. The negative grounds through the base of the unit. I used a $5 bracket from New Holland to bolt it to the base of the ROPS. It took less than 10 minutes to install from start to finish.
Here is a photo of the light installed next to a tool box I also installed behind my seat. Rear Aux work light photo
   / cub cadet 7265 rear work light #4
I added a NAPA tractor light to mine with a rocker switch from VIP on my 7260. Just make sure you fuse it. You can get a fuse tap and stick it in your fuse box. Just be sure to tap the FUSED side. Get some wire loom too to protect the wire.
   / cub cadet 7265 rear work light #5
I ordered just the bracket/mount from my then Cub dealer and then went to NAPA for the light. The bracket was a Cub part, made to attach to the right rear, ROP/light area. I then wired it in with a toggle switch. I don't think the bracket was that expensive. I will try to find the part number if you like although mine is a 7234, a 1996 or 1997 Mitsubishi. Let me know here or via email.
   / cub cadet 7265 rear work light #6
Bracket part number is MA-12187745AGO.
   / cub cadet 7265 rear work light #7
KT,
I put a couple el cheapos on my B7610 Kubota. Photo attached. The thread with a couple more pics is here.
Good luck.
JOB BOX W/ 100K X 20' NYLON SLINGS (A54757)
JOB BOX W/ 100K X...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
(20) Pack of New HD Black Bungee Tie Down Straps (A54865)
(20) Pack of New...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
